Autogenerating geometry in Livelink MATLAB using for loops
Hello, I am currently using the Livelink using MATLAB software and I was wondering if there was an effective way to automate the creation of geometry using for loops.
I would like to be able to be able to make a for loop that will run the create geometry command while changing some parameter such as position while leaving the other parameters unchanged such as for c=1:10
model.component('comp1').geom('geom1').create(ri, 'Rectangle'); model.component('comp1').geom('geom1').feature(ri).set('size', {'width' 'height'*c}); model.component('comp1').geom('geom1').feature(ri).set('pos', {'-width' 'height'});
0 Replies Last Post 13.11.2019, 00:18 GMT-5
Hello Owen Steele
