Postprocessing using min and max in a given time interval
Hello!
I have a very simple post-processing problem for time dependent simulation, but got stuck and couldn't find a way to solve it.
I just need to evaluate the difference between the min and max value of a scalar variable within a given time interval. This difference should then be stored in a table for export. All I found was to evaluate either the max value or the min value (or both, next to each other) but no way to tell Comsol to subtract one from the other...
I also found the two new post-processing functions timeint and timeav in 4.2a, but nothing like timemax or timemin.
Any idea?
Cheers,
Eric
2 Replies Last Post 06.12.2017, 09:17 GMT-5
Posted: 1 decade ago 10.12.2011, 12:50 GMT-5
I'm afraid the easiest is to dump the max an ins in a table and use excel, or export the results to matlab.
But the timemin() and timemax() could be handy indeed ;) perhaps you should suggest them to support
Hi I'm afraid the easiest is to dump the max an ins in a table and use excel, or export the results to matlab. But the timemin() and timemax() could be handy indeed ;) perhaps you should suggest them to support -- Good luck Ivar
Posted: 7 years ago 06.12.2017, 09:17 GMT-5
This is an old thread, but in case someone is still wondering: the timemax and timemin operators do what you want, Eric. See Reference Manual for COMSOL Multiphysics version 5.3, page 252 for its syntax.
Jeff Hiller
This is an old thread, but in case someone is still wondering: the timemax and timemin operators do what you want, Eric. See Reference Manual for COMSOL Multiphysics version 5.3, page 252 for its syntax. Best, Jeff
