How to convert 3D sweep geometry in 2D
Hello everyone, Could you please tell me how can I convert 3D sweep geomtery into 2D or 2D axissymetric? I want to make tortuous uniform diameter pipe in 2D. I want to change my tortuosity each time and diamter have to be remain same. Thank you.
2 Replies Last Post 01.11.2019, 10:54 GMT-4
Posted: 5 years ago 31.10.2019, 16:51 GMT-4
I was quite surprised that the sweep function is not available in 2D. I think I had come across the issue earlier when I found I couldn't for some reasons sweep edges in 3D. Well I found some workaround then.
I am attaching a modified model showing how to obtain a cross section from the 3D component and refer to it in a 2D component. Key is to set up the appropriate work plane that defines the cross section in the 3D component.
This procedure looks a little overengineered and may be, I hope even, there is a simpler method. If not I hope this one works for you.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hi, I was quite surprised that the sweep function is not available in 2D. I think I had come across the issue earlier when I found I couldn't for some reasons sweep edges in 3D. Well I found some workaround then. I am attaching a modified model showing how to obtain a cross section from the 3D component and refer to it in a 2D component. Key is to set up the appropriate work plane that defines the cross section in the 3D component. This procedure looks a little overengineered and may be, I hope even, there is a simpler method. If not I hope this one works for you. Cheers Edgar
Posted: 5 years ago 01.11.2019, 10:54 GMT-4
Updated: 5 years ago 01.11.2019, 06:54 GMT-4
Thank you very much. Right now i am working on 5.3a version, therefore i couldnot able to open the file. Could you please convert this file as 5.3 version. I really appreciate your help. Thank you.
