30.11.2011, 14:21 GMT-5
you have several, but my first idea would be to use a parameter for the water height and run an external Parametric sweep on that water height variable (not a solver continuation one)
30.11.2011, 14:30 GMT-5
Thaks Ivar. Could you be more specific by giving me an example?
In parameter I thought I can only type numbers in expression.
30.11.2011, 15:21 GMT-5
you define a "Definition Parameter" i.e. Param = 0
you define a water height in your geoemtry box model as Height = 10[mm]+Param*[5mm] (my dimensiosn are arbitrary, use what corresponds to your need)
Then in the solver section you add first a PArametric Sweep, then your stationary or time dependent solver or whatever. In the parametric sweep you add the variable Param and you define a range i.e range(0,0.1,1) or whatever you find appropriate.
Then you solve, the parametric sweep will update the geoemtry, mesh, solve, change the parameter Param value, and loop around geometry, meh solver ...
30.11.2011, 17:57 GMT-5
Thanks, Ivar. I really appreciate it.
In post process, I'm trying to show the temperature change on a specific point in structure (done by multiple Cut Points 3D in data set and display them all in 1D plot)
Is there any way of indicating Param value on each line?
If I choose the graph color as cycle, it looks very messy since different points show different colors.
Many Thanks.
Many Thanks.
01.12.2011, 01:56 GMT-5
I'm not sure I got fully the issue, but if you enter your data into a table you can order the table by lines or columns, but you will end up with, I believe in both cases, to have to edit the legend manually within COMSOL. Else you could use matlab and write a script, or export to excel, or matlab or scilab or octave or ....
