Interpolation function with cylindrical coordinates
Hi everyone! I am trying to implement a Custom surface charge on a cylinder in my comsol Model. I'm having a file with cylindrical coordinates %r ,%phi,%a and a Value which is giving the charge and I am trying to Import it but i can't find a working method. (So it would be 3 arguments and Function with position 1)
I deselected "use spatial coordinates as arguments" and under Units i put the Arguments m,deg,m and Function C/m^2 I made a cylindrical coordinate system (sys2) but I cant find out how to use the sys2.r,sys2.phi,sys2.a instead of the x,y,z... so if i plot the interpolated data it is always interpreted as cartesian coordinates instead of cylindrical..
Please help me!! Thanks in advance!
1 Reply Last Post 14.08.2019, 16:20 GMT-4
Posted: 6 years ago 14.08.2019, 16:20 GMT-4
Updated: 6 years ago 14.08.2019, 16:12 GMT-4
As far as I understand the issue you need to allow using spatial coordinates as arguments. If you then apply the function to a boundary condition in cylindrical coordinates it should work. You have to use the function then without arguments. Check the help too!
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
As far as I understand the issue you need to allow using spatial coordinates as arguments. If you then apply the function to a boundary condition in cylindrical coordinates it should work. You have to use the function then without arguments. Check the help too! Cheers Edgar
