Permanent magnet - N42- whatis the magnetization?
please could you help me with my problem - when I would like to simulate perm magnet, what for permeability and magnetization should I input when I only know the grade (N42 or N45 or F30) and the dimensions and mass of the magnet?
thank you
3 Replies Last Post 06.11.2013, 16:00 GMT-5
Posted: 1 decade ago 12.11.2011, 05:51 GMT-5
check out the corresponding magnetisation M, or if you cannot find that on the web get an approximate Tesla value measured close to the magnet (in a free air case, simple model you can reproduce), and adapt your M of your magnet material to get the same freestanding Tesla value in your example model with COMSOL
Hi check out the corresponding magnetisation M, or if you cannot find that on the web get an approximate Tesla value measured close to the magnet (in a free air case, simple model you can reproduce), and adapt your M of your magnet material to get the same freestanding Tesla value in your example model with COMSOL -- Good luck Ivar
Posted: 1 decade ago 06.11.2013, 03:13 GMT-5
I have been working with N42 magnets and use a older Gauss meter for measurement as values for plug in values in this way. The unit values in COMSOL are in Webers. I was wondering if the values were transposed properly as I do not see the m being squared or M-2 in non superscript text. Should I be taking the Square root of the Tesla unit? Otherwise, I am still digging into how to set polarity and spatial blotch regions properly. I appreciate your time and input. COMSOL MULTIPHYSICS is Great. Now all I have to do is figure out how to use it! Independent Researcher, Scott Clark
Posted: 1 decade ago 06.11.2013, 16:00 GMT-5
You can find more detailed Information about the magnetization of N42 Magnets on the Internet, for example here: www.ndfeb-info.com/neodymium_grades.aspx
With that said, you can specfiy the Magnet with a Ampere's Law in the Magnetic Fields Section:
- Select your Magnet as Domain
- In the Magnetic Field Section of the Ampere's Law, select Remanent Flux Density as Constitutive relation
- Set your B_r in the field wich apears
You can find more detailed Information about the magnetization of N42 Magnets on the Internet, for example here: http://www.ndfeb-info.com/neodymium_grades.aspx With that said, you can specfiy the Magnet with a Ampere's Law in the Magnetic Fields Section: - Select your Magnet as Domain - In the Magnetic Field Section of the Ampere's Law, select Remanent Flux Density as Constitutive relation - Set your B_r in the field wich apears
