how to call the displacement of a point in matlab function
I want to add a load by implementing such a function whose dependent variable is the displacement of a point(or the cross section of a beam) at a certain coordinate position. It is a time-dependent research, so the point load application position and the position of the called displacement are all moving.
It can be understood that the displacement of the previous time step will affect the load I applied.
I understand how to add a moving load, but how to call the displacement of a point in a spatial position as a function's dependent variable is a problem.
Thank you!! Liuchong
2 Replies Last Post 08.07.2019, 04:42 GMT-4
Posted: 6 years ago 18.06.2019, 23:17 GMT-4
Updated: 6 years ago 18.06.2019, 23:17 GMT-4
Similar to a probe but can participate in coupling calculations.
Posted: 6 years ago 08.07.2019, 04:42 GMT-4
Updated: 6 years ago 08.07.2019, 04:42 GMT-4
I finally figured it out. Just use this operator, at3(x, y, z, expr), to achieve what I want.
