Saving as java by default, rather than mph
Does anyone know if there is a way to have COMSOL save the modelling currently opened in the GUI as a java file by default, rather than a mph file?
I have written a small script that reads my java everytime it changes and displays the differences with the previous saved version as a html page, but it's slowing me down to always go all the way to File > Save as ... > java
2 Replies Last Post 10.05.2019, 18:54 GMT-4
Posted: 6 years ago 10.05.2019, 10:48 GMT-4
Hi Alexis,
Are you aware that you can compare the mph files directly? See the attached screenshot.
If you want a shortcut for saving as java, you can add a very short model method for that operation. It would only need a single instruction like
model.save("C:\tmp\myfile.java", "java");
Henrik
Henrik Sönnerlind
COMSOL
Hi Alexis, Are you aware that you can compare the mph files directly? See the attached screenshot. If you want a shortcut for saving as java, you can add a very short model method for that operation. It would only need a single instruction like model.save("C:\\tmp\\myfile.java", "java"); Regards, Henrik
Posted: 6 years ago 10.05.2019, 18:54 GMT-4
Updated: 6 years ago 10.05.2019, 18:54 GMT-4
Thanks for your reply!
Sadly I do not have access to model methods as a Linux user, which is frustrating because that would have matched my need exactly.
I never tried the direct comparison, I will give it a go!
Thanks for your reply! Sadly I do not have access to model methods as a Linux user, which is frustrating because that would have matched my need exactly. I never tried the direct comparison, I will give it a go!
