29.10.2011, 03:27 GMT-4
for me that is what COMSOL is using too ;) but you will not see the dA/dt term if you do not turn on temporal time dependent solving.
Are you checking the "Equations" nodes, you will find yourbabies therein, but the list is long ;)
29.10.2011, 12:20 GMT-4
Not all physics modules provided in AC/DC solve for V and A.
For instance, Electric Currents only solves for the steady-state term, grad(V) and Magnetic Fields only solves for the time-varying term, dA/dt.
But there is not a pre-defined physics which includes both.
Is there a reason for this?
30.10.2011, 07:15 GMT-4
solving for V (a scalar) and A (a vector) can be rather RAM heavy, so if you do not need all, why not reduce the number of dependent variables. ACDC is trickier than HT as you have vector components and cross items to consider.
With MEF you solve for V & A, hence time dependent MEF will solve for both. But with more dependnet variables, you must define many more BC's too, and get them correct w.r.t. each others
30.10.2011, 11:40 GMT-4
Ivar,
You have a point about reducing degrees of freedom when possible. So, I suppose that it does make sense to have pre-defined physics with incomplete physical definitions and to couple them, only when, and where, necessary.
But let us assume that you need both V and A, in time:
You mention a time-dependent solution with the MEF formulation, which I thought was magnetostatic only.
Just to clarify, is it possible to do a transient analysis with MEF?
Perhaps I have been wrong all this time, and have been doing it the hard way!
Ivar,
30.10.2011, 12:56 GMT-4
you are right, my fault, I tend to forget the EM distinction ACDC / RF. In ACDC the hypothesis is that the geoemtry is "small compared to a wavelength, and the magnetic effects are rather "immediat" w.r.t any time change.
But if you have dA/dt, how do you incorporate vxB terms ?
I suppose you need today to use MF + EC to get the full formulation, in V and A, in time stepping with COMSOL.
Or you split your work to run the structural part in time domain and MEF in stationary, assuming the magnetic effects to be instantenous w.r.t the rotation or motion of your mechancal part. In MEF as in MF you have the velocity Domain conditions that can be added
30.10.2011, 14:38 GMT-4
I was hoping that I was wrong, and there was a way to get a time-dependent formulation of the MEF governing equations, even though the documentation is very clear.
From page 235 of ACDC Guide:
"...Note that the Magnetic and Electric Currents interface only supports the stationary and frequency domain study types—that is, there is no transient formulation available..."
Thanks for the responses Ivar.
