Time dependency does not compute
Hi again,
In another one of my tests I seem to be having trouble with moving to a time-dependent step. Open up the Helmholtz coils model from the tutorial. delete the stationary step and add a time dependent step instead, and compute. It gives me the Failed to find consistent initial values error. What's going on?
3 Replies Last Post 26.10.2011, 10:53 GMT-4
Posted: 1 decade ago 26.10.2011, 09:05 GMT-4
have you checed that you deleted and reinitiated the solver section correctly, as well as checking if the physics you are using is compatible with time dependent solving ?
Hi have you checed that you deleted and reinitiated the solver section correctly, as well as checking if the physics you are using is compatible with time dependent solving ? -- Good luck Ivar
Posted: 1 decade ago 26.10.2011, 10:24 GMT-4
the reinitiation of the solver section was done correctly, and of course AC/DC works in Time dependent. what can be the cause of inconsistent initial values?
Posted: 1 decade ago 26.10.2011, 10:53 GMT-4
receck your BC's, or just rebuild the model from scratch, something must have gone wrong in there (should though ;)
Hi receck your BC's, or just rebuild the model from scratch, something must have gone wrong in there (should though ;) -- Good luck Ivar
