Simple question regarding parametric sweep of eigenfrequencies
Hello everyone,
I have been an avoid reader of the forum for a while now, and have done my best to find the answer to my question, but I am still getting confused.
My model is very simple. A 2D disc with fixed boundary condition around the perimeter, static, eigenfrequency analysis.
I define a global parameter for the Youngs Mod, E.
I then create a parametric sweep with E as the variable. With values for (10,10,100) in the parameter range box.
The model runs fine and I get the eigenfrequency results for each of the ten models. I am able to go through each result and get the first 6 frequencies, but I would like to get the sweep function to probe the first 6 frequencies and output a CSV file (or similar).
I have been through the rotating blade example, and a few others but am still not sure how to do it.
If anyone would be kind enough to answer, I would really appreciate it.
Thanks very much,
Rob
3 Replies Last Post 17.06.2016, 12:21 GMT-4
Posted: 1 decade ago 18.10.2011, 05:54 GMT-4
Hi everyone,
Does anyone have an idea of how to do this? I think this should be relatively simple?
That is unless I have made an error.
I have been trying to retry the exercises and scour the internet and am still not having much luck.
Am I tight in thinking that I need to define the first, second, third etc eigenfrequencies as parameters?
I would really appreciate some help with this.
Thanks for reading.
Rob
Hi everyone, Does anyone have an idea of how to do this? I think this should be relatively simple? That is unless I have made an error. I have been trying to retry the exercises and scour the internet and am still not having much luck. Am I tight in thinking that I need to define the first, second, third etc eigenfrequencies as parameters? I would really appreciate some help with this. Thanks for reading. Rob
Posted: 1 decade ago 20.10.2011, 05:52 GMT-4
Figured it out...
Set up a parametric sweep.
Once it runs, go to DERIVED VALUES, then GLOBAL EVALUATION
Choose the data you need and then it will create a table for you.
Thanks for the help
Rob
Figured it out... Set up a parametric sweep. Once it runs, go to DERIVED VALUES, then GLOBAL EVALUATION Choose the data you need and then it will create a table for you. Thanks for the help Rob
Posted: 9 years ago 17.06.2016, 12:21 GMT-4
Thank you for finding that and posting it.
You answered one of my questions.
Thank you for finding that and posting it. You answered one of my questions.
