Henrik Sönnerlind
COMSOL Employee
5 years ago
02.04.2019, 07:37 GMT-4
More elegant is to use the built in time derivative of the temperature, 'Tt'.
Henrik
Henrik Sönnerlind
COMSOL
Henrik
5 years ago
03.04.2019, 08:30 GMT-4
thank you for your answer. But I still have a similar problem: Variable Tt cannot be evaluated.
The problem is in the first step I think. I do have the starting temperature T at t=0 for all points in x,y,z.
The problem was with the older method using prev() that I could not evaluate dT/dt at the first point as I do not have enough Data. I think this time I have a similar problem. If necessarily could even provide an initial value for Tt, if I would know where to assign the initial value of Tt.
Currently I do have an analytic function defined in the components and I just used Tt for the cooling rate.
Kind regards,
Christian
Kind regards,
Christian
Henrik Sönnerlind
COMSOL Employee
5 years ago
03.04.2019, 10:53 GMT-4
Hi Christian,
What study type (and settings) are you using?
Henrik
Henrik Sönnerlind
COMSOL
Hi Christian,
Henrik
5 years ago
03.04.2019, 11:05 GMT-4
Hi Henrik,
My Study looks like this:
I am using an optimization and as Step 1 I use a Time Dependent Study Step.
In the Solver Configurations the optimization solver is also time dependent.
The error appears in the optimization solver (as I use my function as an Objective for my optimization).
Kind regards,
Christian
Hi Henrik,
Kind regards,
Christian
Henrik Sönnerlind
COMSOL Employee
5 years ago
05.04.2019, 02:57 GMT-4
Hi Christian,
I think you should either contact support, or upload a simplified version of your model here.
Henrik
Henrik Sönnerlind
COMSOL
Hi Christian,
Henrik
