Undefined Value found in Boundary Condition Analysis
Posted 12.10.2011, 18:34 GMT-4 RF & Microwave Engineering Version 4.2 10 Replies
I am doing boundary condition analysis in RF module (plus frequency analysis). I defined frequency as a parameter. For certain frequency it works without any problem. However when I change the frequency from the parameters, it gives an error:
"Undefined value found.
- Detail: NaN_or_Inf_found_when_solving_linear_system_using_SOR
What could be the reason for this? I did not change anything else in the file...
I would appreciate any help.
Damla
could it be that you are hitting straight on a resonance, and your values grow out of bound for a "Double Float" ?
When I do modal sweeps, I always do my best to avoid direct vicinity of resonances, except if I have a lot of damping, which by default is seldom the case. This applies in all generality from Structural to ACDC to RF ...
I have the same problem. I did the simulation of Photonic Crystal Fiber by using RF module. When I simulated my PCF model in frequency 2e13 Hz , it works. But, when I increased the frequency in 2e14 Hz, it did not work. What your opinion with this case?
Thank's for your attention.
Haris
I mean that, when I increased the frequency in my simulation of Photonic Crystal Fiber, there is an error message
""Undefined value found.
Do you have an idea for this problem?
Thank's
Haris
not really NaN is not a a number hence some undefined values, or underflow/overflow
Have you cheked that your emsh is compatible with the wavelength at those high frequencies ?
I'm beginner, so i don't know How to check compatibility my mesh and frequency? Would you like share to me, How to check compatibiliy between mesh and frequency? If it is not compatible, Does the mesh must be changed?
thank's
Haris
I agree its difficult to learn all the underlaying hypothesis for all physics rapidly, it takes some time. First of all index the pdf files of the help and search in these with keywords, then take time to read (even acouple of times) the doc, particulrly the one related to your specific physics, i.e. RF.
Meshing is like digital sampling. most people have understood by now tha when digitising any time varying signal one must have enough samples to resolve correctly the highest frequency, otherwise one get aliasing. With FEm its the same. The mesh is sampling your domain and boundaries, on which are running functions that have gradients (slopes or even harmonic shapes) and these must be samples correctly. particularly in the time domain, when you can have very steep gradients along some boundaries, then the mesh will not correctly take into account these gradients and your results is wrong, or the solver gets lost, at best run for a looong time.
With RF the main issue is to say what is the wavelength of my EM wave in the different media (wavelength in air and glass are not the same because of the index of refraction of glass. So you need at least 5 ideally 10 mesh elements per spatial wave-length in all materials.
Now knowing your frequency and the medium (n) you can get the wavelength, find the shortest, and divide by 5 or 10: this is the max mesh size for RF ! you can also plot "h" over your meshed domains to see the actual values you have and compare to the desired one. You might end up with so many elements that you do not have enough RAM.
Then you must think how to reduce the size of your model, Use symmetry or perhaps a 2D-axi or 2DD instead of 3D etc
Thank's Ivar, your explanation is very detail. It's reasonable, my meshing size isn't compatible for frequency 2e14 Hz. When I decrease the meshing size, it means that the number of elements increase and it's very hard for my computer. I think, I have to use the other technique.
Best regards
Haris
I have simulated mode analysis of PCF (photonic crystal fiber), and I obtain the effective mode index is 1.459941 (6 decimals places after coma). I want to increase the accuracy of result, it means that I want to get the result 12 decimals places after coma. Do you know, how to do that?
Thank's
Haris
I have simulated mode analysis of PCF (photonic crystal fiber) by using comsol 4.1, and I obtain the effective mode index is 1.459941 (6 decimals places after coma). I want to increase the accuracy of result, it means that I want to get the result 12 decimals places after coma. Do you know, how to do that?
Thank's
Haris
you can ask COMSOL to display all digits (check the doc, the preference and the full precision icon in the table view), and try to tweak your solver settings to continue solving to a higher resolution, but then you need also a more dense mesh, and be sure you have no irregularities.
Anyhow computing on todays PC's, even with double precision, gives only about 6 digits sure in good conditions, due to the way the binary system represents the "real" numbers.
Anyhow, I seldom trust more than 3 digits, a model is an approximation, no "true" value
Suggested Content
- BLOG Performing Topology Optimization with the Density Method
- KNOWLEDGE BASE What to do when a linear stationary model is not solving
- FORUM Undefined value found
- FORUM sigst variable undefined
- KNOWLEDGE BASE Initial guess leads to undefined function value
