Run COMSOL @ remote PC -> JAVA error!!!
Hi guys! I'm trying to run COMSOL to simulate myscript.m file, which works perfectly on my PC, in another PC.
This is what I did:
ssh -X etc etc
cd myfolder
nohup ./mybash.sh &
in mybash.sh I got this:
time comsol35 -np 2 -tmpdir $mytemp batch myscript > mylog.log
everything starts and should be OK but if I exit with exit command from the machine and then re-login in the nohup's output file I got this:
X connection to localhost:10.0 host broken (explicit kill or server shutdown)
pure virtual method called
/usr/bin/comsol35: line 2345: 7820 Aborted ${MPICMD} ${JAVA} ${JVMARGS} ${CLTMPARG} -classpath ${FLCP} ${SHOWVERSION} ${MAINCLASSARG} ${APPLARGS}
2066.28user 427.27system 42:14.13elapsed 98%CPU (0avgtext+0avgdata 0maxresident)k
0inputs+0outputs (44major+4698982minor)pagefaults 0swaps
suggestions!?
1 Reply Last Post 03.03.2014, 15:04 GMT-5
Hello Luca Borromei
Posted: 1 decade ago 03.03.2014, 15:04 GMT-5
I'm running into a similar problem. Trying to run comsol 4.4 on a linux server. I'm SSH'd into the linux server from windows running XMing. (good X Server) Everything is fine with the SSH/X11 setup, I can run other problems on the linux server like matlab, etc. But when I run comsol 4.4, I get the error:
And then the program bombs.
I'm guessing one can't run comsol through and X11 pipe?
Alex
I'm running into a similar problem. Trying to run comsol 4.4 on a linux server. I'm SSH'd into the linux server from windows running XMing. (good X Server) Everything is fine with the SSH/X11 setup, I can run other problems on the linux server like matlab, etc. But when I run comsol 4.4, I get the error: pure virtual method called ... ... ... And then the program bombs. I'm guessing one can't run comsol through and X11 pipe? Alex
