Gunnar Andersson
COMSOL Employee
6 years ago
04.01.2019, 02:11 GMT-5
It sounds as if you try to start the x64 Native Tools Command Prompt for VS 2017 from within Visual Studio 2017. You should instead start it from the start menu - see the attached image.
6 years ago
04.01.2019, 09:26 GMT-5
Hi, Gunnar Andersson:
I found it! Thank you so much for your valuble reply.
However, I encountered a confusion when trying to compile a self-defined model which contains the utility functions. In the users' Guide, the third step is to input
"link /OUT:ext.dll /DLL ext.obj
C:\Program Files\COMSOL\COMSOL54\Multiphysics\data\extmat\win64\csextutils.lib"
into the command line. I found the .dll file has already created after only inputing the first line in the quote above. So I am wondering what is functionality of the file path in the second line. Is it correct if we neglect it? And should I input contents in the quote in one line or two lines?
Thank you so much for your time and help.
Yu
Yu Zhang
Yu
