Module for calculating the fault current in grid dc
Dear all, Hoping all is doing well with you. I'm asking for a module for calculationg the earth curent in a grid high voltage DC. Also the name of Multiphysics. Kindest Regards Samar
Samar Akef
RA&TA at AUC in Cairo
1 Reply Last Post 31.12.2018, 13:06 GMT-5
Posted: 6 years ago 31.12.2018, 13:06 GMT-5
Updated: 6 years ago 11.01.2019, 16:39 GMT-5
It would be the short circuit current of the battery bank. I'm not sure if manufacturers test for this and publish the results, but if they don't, the calculation I'd recommend for estimating it, would be open circuit voltage / internal resistance at maximum operating load. I wouldn't be surprised if it weren't common to test for this, as it certainly would ruin the battery and likely be dangerous to do a direct test.
percentage calculator
It would be the short circuit current of the battery bank. I'm not sure if manufacturers test for this and publish the results, but if they don't, the calculation I'd recommend for estimating it, would be open circuit voltage / internal resistance at maximum operating load. I wouldn't be surprised if it weren't common to test for this, as it certainly would ruin the battery and likely be dangerous to do a direct test. [percentage calculator](https://percentagescalculator.com/)
