time dependent problem with two physics
i am working on problem where i have apply two physics
1) electric current
and
2)solid mechanics
i want to apply the body load from time 0sec to 4sec
and want to apply current during time 2sec to 4sec
i tried to see the results but it only show the results during the time 2sec to 4sec
i want to see the results from 0 to 4sec
how can i do this should i use one time dependent study or i need two time dependent.
5 Replies Last Post 19.08.2011, 16:11 GMT-4
Posted: 1 decade ago 18.08.2011, 12:24 GMT-4
I think an easy way to do it might be this
since you are applying your load for the entire duration you dont need to change it
for applying current you can try
Current*(t>=2)
This will then only run the current for time t>=2
I think this will work
I think an easy way to do it might be this since you are applying your load for the entire duration you dont need to change it for applying current you can try Current*(t>=2) This will then only run the current for time t>=2 I think this will work
Posted: 1 decade ago 18.08.2011, 16:08 GMT-4
this might give you some convergence issues, to be tested,
if so, use rather the "pulse" function that has smoothed turn-on/off transitions
Hi this might give you some convergence issues, to be tested, if so, use rather the "pulse" function that has smoothed turn-on/off transitions -- Good luck Ivar
Posted: 1 decade ago 19.08.2011, 05:51 GMT-4
it did not work out with this T>=2
Posted: 1 decade ago 19.08.2011, 05:55 GMT-4
i am new in using the time dependent model. dont know exactly how to use the pulse source. for two or three physics model do we need separate time dependent studies.
i tried to see example on the website most examples are stationary study
please guide me to find good examples for time dependent problems
i am new in using the time dependent model. dont know exactly how to use the pulse source. for two or three physics model do we need separate time dependent studies. i tried to see example on the website most examples are stationary study please guide me to find good examples for time dependent problems
Posted: 1 decade ago 19.08.2011, 16:11 GMT-4
you can solve all either in one go, or in a segregated way variable by variable, or iteratively, all depends on how the variables are inter-dependent, and how much RAM you need and you have available.
There is no "one" way. But mostly COMSOL proposes a default way quite OK
Hi you can solve all either in one go, or in a segregated way variable by variable, or iteratively, all depends on how the variables are inter-dependent, and how much RAM you need and you have available. There is no "one" way. But mostly COMSOL proposes a default way quite OK -- Good luck Ivar
