How to add 2D image from MATLAB to COMSOL as a geometry?
Hi all,
I have an 2D image with a size of 512x512. It's a section image from a CT image as DICOM. I converted it to .mat file by using dicomread() function in MATLAB. After that i want to import it as a geometry to a 2D empty model in COMSOL. Is there any method to do it?
BTW i solved the problem by converting DICOM file to .DXF to add as geometry. But I wonder can i convert 2D image .mat file to stl or another format suitable for importing to Comsol geometry?
2 Replies Last Post 16.12.2018, 18:49 GMT-5
Posted: 6 years ago 13.12.2018, 04:00 GMT-5
mphimage2geom should be a good starting point.
Lars Gregersen
Comsol Denmark
Hi mphimage2geom should be a good starting point.
Posted: 6 years ago 16.12.2018, 18:49 GMT-5
Thank you Lars,
I really appreciate your helps! Thank u so much!
Regards.
>Hi > >mphimage2geom should be a good starting point. Thank you Lars, I really appreciate your helps! Thank u so much! Regards.
