Plots and deformation with prescribed displacement
Hi!
I'm working on a project where a domain shrinks because of a chemical transformation (AlAs -> AlOx). Given there is no physics handling atom diffusion and chemical transformations in solids in COMSOL (as far as i know), I tried to use the "prescribed displacement" function, my goal only being to study the strains and the displacement occuring in other domains of the structure.
But i'm a little puzzeld by the results; whereas the plots seem fine when I don't represent the deformations, it become rubbish when i try to plot them, with overlapping boudaries, displacement with no relations whatsoever with the values I prescribed earlier, and so on.
It is not critical to me to get those deformations on my plots, but it would make more sense and be more self explanatory with them, for exemple to show my results to colleagues.
Any idea where it could come from?
Thank you very much.
Antoine
Ps: note that it does not occure only with prescribed displacement but also when a fixed load is applied for exemple.
I'm using linux and comsol 4.2.
2 Replies Last Post 05.08.2011, 03:46 GMT-4
Posted: 1 decade ago 29.07.2011, 11:15 GMT-4
can it be related to the by default automatic scaling of the deformation plots, you can manually set the scale in the deformation plot node
Hi can it be related to the by default automatic scaling of the deformation plots, you can manually set the scale in the deformation plot node -- Good luck Ivar
Posted: 1 decade ago 05.08.2011, 03:46 GMT-4
Yes, that's it, thanks for your help.
Antoine Gerlaud
Yes, that's it, thanks for your help. Antoine Gerlaud
