Conjugate Heat Transfer, Duct Boundary Conditions?
I have successfully modeled forced convection over a heat sink. I have a known inlet temperature and velocity. I have run into problems when I add a duct geometry about the heat sink and air. My first question is about the boundary conditions on the outside of the duct. At first, I used a fixed temperature equal to the ambient temperature. I believe that is causing a cooler solution than reality. My next attempt was to use surface-to-ambient radiation on the exterior of the duct with a know emissivity and ambient temperature.
I have not yet found an acceptable solution with this method. Does there need to be a know medium outside the duct to radiate to?
Thanks for your help
1 Reply Last Post 21.07.2011, 08:11 GMT-4
Hello Matthew Williamson
Posted: 1 decade ago 21.07.2011, 08:11 GMT-4
Hi there,
You can convective flux as a boundary condition.
Hi there, You can convective flux as a boundary condition.
