Comsol with Matlab v4.1, equivalence with v3.5a POSTPLOT
I am solving a heat tranfer problem with COMSOL.
Workin with v3.5a I created an *.m file in Matlab and I used the postplot function to obtain the isotherm at 3000K
H=postplot(fem, ...
'isodata',{'T','cont','internal','unit','K'}, ...
'solnum','end', ...
'outtype','postdata',...
'isodlim',[3000 3000]);
Then, in H{1}.p there were the coordinates of the cloud of points forming this isotherm.
How could I do the same thing with the new version v4.1? I need the coordinates of the points and I haven´t been able to find them in Matlab.
Itxaso
3 Replies Last Post 04.07.2011, 04:59 GMT-4
Posted: 1 decade ago 26.05.2011, 04:27 GMT-4
Hi Itxaso
Create a plot of the contour or isosurface using the Comsol Desktop.
Read the section on "Extracting Data" on page 375 of the API Reference Guide.
Lars Gregersen
Comsol Denmark
Hi Itxaso Create a plot of the contour or isosurface using the Comsol Desktop. Read the section on "Extracting Data" on page 375 of the API Reference Guide. Lars Gregersen Comsol Denmark
Posted: 1 decade ago 01.07.2011, 10:23 GMT-4
I have the same problem. I need to get the values of a streamline in MATLAB from an old code with COMSOL 3.5. Before I used the lines:
p=postplot(fem, ...
'flowdata',{'Er_emqv','Ez_emqv'}, ...
'flowstart',{[r0],[z0]}, ...
'solnum','end', ...
'Outtype','postdata');
but I need to do the same now in MATLAB with COMSOL 4? How can I do it? The API documentation you suggested in not really clear and may not apply to my case.
Regards
Marley
I have the same problem. I need to get the values of a streamline in MATLAB from an old code with COMSOL 3.5. Before I used the lines: p=postplot(fem, ... 'flowdata',{'Er_emqv','Ez_emqv'}, ... 'flowstart',{[r0],[z0]}, ... 'solnum','end', ... 'Outtype','postdata'); but I need to do the same now in MATLAB with COMSOL 4? How can I do it? The API documentation you suggested in not really clear and may not apply to my case. Regards Marley
Posted: 1 decade ago 04.07.2011, 04:59 GMT-4
Hi Marley,
I didn't find the way to get the coordinates of the points with Matlab, but if you have your model solved in Comsol 4, you can extract the data and then import them in Matlab.
In Comsol, plot the streamline. Then, under "Results" in the "Model Builder", rigth-click "Report" and select "Data". Under "Data set" select your Streamline. Choose the folder and the name you want to save it and click the "Export" button. You obtain a *.txt file containing the data that you can then import in Matlab.
That is how I got it finally. I hope this helps you.
Itxaso
Hi Marley, I didn't find the way to get the coordinates of the points with Matlab, but if you have your model solved in Comsol 4, you can extract the data and then import them in Matlab. In Comsol, plot the streamline. Then, under "Results" in the "Model Builder", rigth-click "Report" and select "Data". Under "Data set" select your Streamline. Choose the folder and the name you want to save it and click the "Export" button. You obtain a *.txt file containing the data that you can then import in Matlab. That is how I got it finally. I hope this helps you. Itxaso
