COMSOL UBUNTU PROBLEM urgent
Posted 20.05.2011, 10:08 GMT-4 Version 4.2 4 Replies
i am new to linux.. i have installed COMSOL 4.1 on ubuntu 10.4 but i am unable to run, i m getting this error please suggest detailed solution
The program 'SWT' received an X Window System error.
This probably reflects a bug in the program.
The error was 'BadDrawable (invalid Pixmap or Window parameter)'.
(Details: serial 2105 error_code 9 request_code 136 minor_code 3)
(Note to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it.
To debug your program, run it with the --sync command line
option to change this behavior. You can then get a meaningful
backtrace from your debugger if you break on the gdk_x_error() function.)
Error:-8
Error:-8
4 Replies Last Post 20.07.2011, 01:01 GMT-4
