Error message: Failed to evaluate expression. Failed to evaluate operator. Failed to evaluate variable.
Hi people
I have been encountering this error message:
- Expression: d(d((-(mod1.chds.nx*mod1.chds.u+mod1.chds.ny*mod1.chds.v+mod1.chds.nz*mod1.chds.w)*mod1.c*test(mod1.c))*(dvol),{test@1}),mod1.c)
- Operator: mean
- Geometry: 1
- Boundary: 42 81 82
I have been working around with boundary conditions, initial values suchlike, but I am not sure if I am on the right track because I either receive the error message above or this error message:
- Expression: mod1.p-mod1.dl.p0
- Variable: mod1.dl.p0
- Defined as: (g const*(mod1.dl.H0*mod1.dl.rho))
- Operator: mean
- Geometry: 1
- Boundary: 42 81 82 83
Why are all these error messages?
Thanks in advanced!
regards
Liwah
3 Replies Last Post 31.03.2014, 17:16 GMT-4
Hello LiWah Wong
Mohammad Mostakhdemin
Posted: 1 decade ago 26.03.2014, 03:52 GMT-4
I am also have the same error what should we do
Thanks in advanced
Regards Mohammad
I am also have the same error what should we do Thanks in advanced Regards Mohammad
Posted: 1 decade ago 31.03.2014, 17:11 GMT-4
D
-- D
Posted: 1 decade ago 31.03.2014, 17:16 GMT-4
same here
I am trying to plot the resistance(x-axis) vs voltage(y-axis) 1D relation by fixing the vibration frequency at 72Hz ,but it gave me error: "Failed to evaluate variable "
I have added 2 physics : AC/DC circuit and piezo-electric device
I have set up "Parametric sweep" of resistor from 1e5 to 1e6 ( 10 steps)
I have added frequency domain study by fixing the vibration frequency at 72Hz and select fully coupled
I am not sure if I set up studies correctly , should I add "stationary study" after "frequency domain" study?
or should I use "frequency domain model" study?
I am confused
same here I am trying to plot the resistance(x-axis) vs voltage(y-axis) 1D relation by fixing the vibration frequency at 72Hz ,but it gave me error: "Failed to evaluate variable " I have added 2 physics : AC/DC circuit and piezo-electric device I have set up "Parametric sweep" of resistor from 1e5 to 1e6 ( 10 steps) I have added frequency domain study by fixing the vibration frequency at 72Hz and select fully coupled I am not sure if I set up studies correctly , should I add "stationary study" after "frequency domain" study? or should I use "frequency domain model" study? I am confused
