Nirmal Paudel
Tribhuvan University/Electrical Engineering
6 years ago
16.04.2018, 09:34 GMT-4
You can certainly build 3D coils in MEF physics interface.
However, you would need to understand the limitation of Velocity (Lorentz Term). Here is note from one of my blog post:
https://www.comsol.com/blogs/modeling-magnetic-bearings-in-comsol-multiphysics/
Note that the Velocity (Lorentz Term) feature can only be used when the moving domain does not contain prescribed magnetic sources like coils or permanent magnets that move along with the material. The moving domains must also be invariant in the direction of motion. For instance, the Velocity (Lorentz Term) feature can be used to model conductive homogeneous spinning disks. Some examples include magnetic brakes, an electrodynamic bearing, a homopolar generator, magnets over a moving infinite homogeneous plane (such as a falling magnet through a copper tube or maglev trains), and a flow of homogeneous conducting fluid past a magnet (such as liquid metal pumps or hall generators/thrusters).
Note: The Lorentz term accurately accounts for induction in a moving domain caused by stationary magnetic sources, provided the moving domain (including its material properties) does not change in the direction of motion. In addition, induction may be caused by temporal changes to either the strength of the stationary sources or a changing velocity. The Lorentz term does not incorporate the effect of such temporal changes.
If you have the above mentioned limitation, you would need to solve the model using Magnetic Fields and Moving Mesh. That is physically, including the translational motion of coil using the Moving Mesh interface.
Best Regards,
Nirmal Paudel
Best Regards,
Nirmal Paudel
6 years ago
16.04.2018, 23:35 GMT-4
Thank you very much. I understand that I should handle it with moving mesh.
