CFD Model with trbolent flow
Can anybody help me with turbulent flow model.
Badically I am working on Transient conjugate heat transfer turbulent flow model.
The error is : Segregated Group.
Your help in this regard is highly appreciable.
Ishant
1 Reply Last Post 25.04.2011, 04:24 GMT-4
Posted: 1 decade ago 25.04.2011, 04:24 GMT-4
the "old" V4.0 does not set up always all modules in the solver section, if you fiddle with your model, its worth to delete and regenerate your study regularly (but you loose the results and plot settings each time).
An advice: upgrade to V4.1 and you will be less frustrated.
Hi the "old" V4.0 does not set up always all modules in the solver section, if you fiddle with your model, its worth to delete and regenerate your study regularly (but you loose the results and plot settings each time). An advice: upgrade to V4.1 and you will be less frustrated. -- Good luck Ivar
