starting Comsol 4.x with Matlab without opening additional console window (Linux)
i want to run Comsol 4.x with Matlab on a Linux Server. I connect to that server via ssh and want to keep my Comsol/Matlab session running after logging of by using 'screen' command.
The problem is that Comsol 4 opens a new console window in which Comsol/Matlab is running. That makes it impossible to use screen command which only works for the current console.
Is there a way to start Comsol 4.x with Matlab in the same console without opening a new window?
Best regards
3 Replies Last Post 22.02.2012, 06:34 GMT-5
Posted: 1 decade ago 20.04.2011, 04:09 GMT-4
Use the command
comsol server matlab -mlroot MATLAB_path &
See also:
www.comsol.com/support/knowledgebase/1059/
Niklas
Best regards
Niklas
Use the command comsol server matlab -mlroot MATLAB_path & See also: http://www.comsol.com/support/knowledgebase/1059/ Niklas [QUOTE] Hi, i want to run Comsol 4.x with Matlab on a Linux Server. I connect to that server via ssh and want to keep my Comsol/Matlab session running after logging of by using 'screen' command. The problem is that Comsol 4 opens a new console window in which Comsol/Matlab is running. That makes it impossible to use screen command which only works for the current console. Is there a way to start Comsol 4.x with Matlab in the same console without opening a new window? Best regards [/QUOTE] -- Niklas
Posted: 1 decade ago 20.04.2011, 17:09 GMT-4
Hi Niklas,
thank you for you help. I use ssh to connect to the server at my university and then i try to use Comsol 4.0 with Matlab without X-forwarding:
comsol-4.0 server matlab -mlroot /opt/matlab-7.9.0/ &
Unfortunately the command still causes a GTK-error. So somehow Comsol still tries to open a (GTK) window. Any ideas how to get Comsol 4 and Matlab running in a console window?
Hi Niklas, thank you for you help. I use ssh to connect to the server at my university and then i try to use Comsol 4.0 with Matlab without X-forwarding: comsol-4.0 server matlab -mlroot /opt/matlab-7.9.0/ & Unfortunately the command still causes a GTK-error. So somehow Comsol still tries to open a (GTK) window. Any ideas how to get Comsol 4 and Matlab running in a console window?
Posted: 1 decade ago 22.02.2012, 06:34 GMT-5
Same problem with version 4.2. There does not seem to be a -nodisplay option. Even with the options -nodesktop and -mlnosplash, still tries to open a window. This precludes me from using queuing software to run comsol/matlab scripts - I have to keep a console window open and connected for the duration of the job... not very practical. Is there presently a way to get around this or is something in the works for future versions?
Martin
Same problem with version 4.2. There does not seem to be a -nodisplay option. Even with the options -nodesktop and -mlnosplash, still tries to open a window. This precludes me from using queuing software to run comsol/matlab scripts - I have to keep a console window open and connected for the duration of the job... not very practical. Is there presently a way to get around this or is something in the works for future versions? Thanks, Martin
