Help regarding Laser Simulation and Time Step
Posted 12.04.2011, 13:34 GMT-4 Heat Transfer & Phase Change 1 Reply
I am extremely new to Comsol and so I apologize if my question is simplistic.
I am trying to model a laser beam with an even distribution in one direction and a Gaussian profile in the other. At the focal point the beam is 0.5mm x 12mm and the beam comes in at a 19 degree angle, the power of the laser is 4 kW. I want to be able to vary how far the focal point is from the surface of the object and the position where the beam is (not in the simulation just before I run it). Does anyone have a suggestion of how to model it so that I can vary these?
As well when I ran a model I had many time steps but all of the time steps looked identical (from 0.1 s - 10 s). Is there some option I have to change to see how the heat flow progresses?
Again I apologize for the probably simplistic questions.
Thank you for any assistance,
John
Hello John Haase
