Multiple plane wave sources
Given an antenna array of half wave dipoles. I want to measure terminal voltage at each antenna terminal when multiple plane waves are incident upon this array from different directions.
I need to know how to have multiple, independent plane wave sources in simulation?, for example one source at phi=45 degrees and the other at phi=50 degrees and many more possible.
Irfan
2 Replies Last Post 13.04.2011, 09:52 GMT-4
Posted: 1 decade ago 12.04.2011, 05:29 GMT-4
Are you using scattering module? In that case I feel that you could just write the analytical expression of impinging plane waves in the incident field and that should do the trick.
Posted: 1 decade ago 13.04.2011, 09:52 GMT-4
Thanks Shakeeb, I got this reply from COMSOL support too;
"Dear Irfan,
Thank you for contacting COMSOL Support.
Setting up multiple plane waves is the same as setting up a single plane
wave. Whereas you might currently write:
exp(j*emw.k0*(x*cos(phi)+y*sin(phi)))
you could write:
exp(j*emw.k0*(x*cos(phi)+y*sin(phi)))+exp(j*emw.k0*(x*cos(phi2)+y*sin(phi2)))
where phi and phi2 and so on are your angles of interest, and so on.
Best Regards,
Your COMSOL Technical Support Team"
Thanks Shakeeb, I got this reply from COMSOL support too; "Dear Irfan, Thank you for contacting COMSOL Support. Setting up multiple plane waves is the same as setting up a single plane wave. Whereas you might currently write: exp(j*emw.k0*(x*cos(phi)+y*sin(phi))) you could write: exp(j*emw.k0*(x*cos(phi)+y*sin(phi)))+exp(j*emw.k0*(x*cos(phi2)+y*sin(phi2))) where phi and phi2 and so on are your angles of interest, and so on. Best Regards, Your COMSOL Technical Support Team"
