How to define a maximum value for a dependent variable?
I have been trying to develop a performance model for an electrochemical system.
However, I got some evaluation errors of powers or logarithms when starting
the solver. This is due to concentrations getting negative values at some
solver step. I need to assure that I do not evaluate negative values, and use a maximum concentration value for all species like max(1e-9, c).
How can I define it?
Ertan
2 Replies Last Post 17.06.2015, 01:42 GMT-4
Posted: 1 decade ago 12.04.2011, 20:13 GMT-4
I have just found how to define it. If you use max(c, 1e-9) everywhere in the model instead of "c", the max function will return 1e-9 if the concetration is lower than 1e-9. Therefore, you can eliminate errors due to getting negative concentrations values at some solver step.
Posted: 9 years ago 17.06.2015, 01:42 GMT-4
where have I to type in the function?
Adnan
Hi, where have I to type in the function? Best regards, Adnan
