function for distribution of discrete values (0 and 1)
hi all,
I am new to COMSOL. I was wondering if somebody can help me with this. I want to make a function that gives me 20% (by area) distribution of value 1 and remaining 80% area the value of zero. I could not do it using random function of COMSOL. Appreciate your help already.
best regards,
5 Replies Last Post 19.02.2018, 02:38 GMT-5
Posted: 7 years ago 13.02.2018, 08:46 GMT-5
though i can do it in matlab using randsrc function. i can generate a matrix of any order comprising of zero and one according to a probability function. but cannot do it in comsol.
Posted: 7 years ago 15.02.2018, 04:31 GMT-5
i am still stuck on this. if somebody could help it will be really helpful.
Posted: 7 years ago 15.02.2018, 07:43 GMT-5
Hi Zahid,
You do not really tell why you cannot use the built-in random function. If you just want a randomized variable over the domain to take the value 0 or 1 with an expected value of 0.2, you can write an expression like
Here rn1 is the built-in random function, but shifted so that it is uniform over the interval [0,1].
Henrik
Henrik Sönnerlind
COMSOL
Hi Zahid, You do not really tell why you cannot use the built-in random function. If you just want a randomized variable over the domain to take the value 0 or 1 with an expected value of 0.2, you can write an expression like rn1(X,Y)
Posted: 7 years ago 16.02.2018, 15:32 GMT-5
Dear Henrik.
Thanks alot for your response. I actually am working on phase field modeling for phase transformation. I want my initial domain to consist of Phase 'A' (20% of the material by area) with a value of 0 and another Phase 'B' (80% of the material by area). For this problem, I need to make a function that gives me these two discreet values randomly distributed. I hope you understood it now more clearly. I dont want to make two separate domains for both phases and assign two different functions for them.
Dear Henrik. Thanks alot for your response. I actually am working on phase field modeling for phase transformation. I want my initial domain to consist of Phase 'A' (20% of the material by area) with a value of 0 and another Phase 'B' (80% of the material by area). For this problem, I need to make a function that gives me these two discreet values randomly distributed. I hope you understood it now more clearly. I dont want to make two separate domains for both phases and assign two different functions for them.
Posted: 7 years ago 19.02.2018, 02:38 GMT-5
Hi Zahid,
The expression I wrote in my previous post does exactly that: Generates two discrete values randomly distrubuted. They will however also be randomly distributed within each element, and that may not be what you want.
If you for example want each element to have the value 1 or 0, then you have to feed the random function with the element number, rather that by the coordinates, as in my example.
If you want larger contiguous regions, then it is trickier.
Henrik
Henrik Sönnerlind
COMSOL
Hi Zahid, The expression I wrote in my previous post does exactly that: Generates two discrete values randomly distrubuted. They will however also be randomly distributed within each element, and that may not be what you want. If you for example want each element to have the value 1 or 0, then you have to feed the random function with the element number, rather that by the coordinates, as in my example. If you want larger contiguous regions, then it is trickier. Regards, Henrik
