Jeff Hiller
COMSOL Employee
7 years ago
21.12.2017, 11:05 GMT-5
Good guess! See Reference Manual for COMSOL Multiphysics, version 5.3a, page 244. All documentation is accessible through File > Help > Documentation.
Jeff Hiller
7 years ago
26.12.2017, 12:43 GMT-5
I checked on the documentation for Comsol 5.3, but I don't understand if the expression MIN can be used in my case, since the arguments are variables. I read that there is also ATTIMEMIN, but I think is not useful for my case, since I need to define the viscosity imposed as user defined in the Laminar Flow under Fluid Properties as the minimum between the two variables. It's not a result evaluation.
I tried to run the code using n=min(nT,nY), but the simulation gives error after a while during the calculations.
Valentina
Valentina
Jeff Hiller
COMSOL Employee
7 years ago
02.01.2018, 09:17 GMT-5
Hello Valentina,
Min should work even for variables, so I suspect the source of your problem is somewhere else.
I recommend you contact COMSOL's support team at support@comsol.com .
Jeff Hiller
Hello Valentina,
7 years ago
07.01.2018, 05:58 GMT-5
Thank you so much,
all the best,
Vale
Thank you so much,
all the best,
Vale
7 years ago
08.01.2018, 14:37 GMT-5
Updated:
7 years ago
08.01.2018, 14:39 GMT-5
I got this error when I try to run the model:
Velocity u, Pressure p
Attempt to evaluate negative power of zero.
- Function: ^
Failed to evaluate temporary symbolic derivative variable.
- Variable: epII@VDN$mod.ux
- Defined as: (0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11))
- Variable: nb@VDN$mod.ux
- Defined as: (((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2))
- Variable: n@VDN$mod.ux
- Defined as: (nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2)))
- Variable: mod.spf.mu@VDN$mod.ux
- Variable: mod.spf.mu_eff@VDN$mod.ux
- Variable: mod.spf.K_stress_tensorxz@VDN$mod.ux
- Defined as: (mod.uz+mod.wx)((nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2))))
- Expression: dvol(-((mod.uz+mod.wx)((nT>nb)((((0.5((0.5((((2(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))(0.5(2ep11)))1.4142135623730951)((-(c0-(((fcrho)g)z)))/((epII1.4142135623730951)^2))))))
Failed to evaluate Jacobian of expression.
- Expression: dvol(-mod.spf.K_stress_tensorxz)
- Expression: ((mod.p-mod.spf.K_stress_tensorxx)test(mod.ux)-mod.spf.K_stress_tensorxytest(mod.uy)-mod.spf.K_stress_tensorxztest(mod.uz)-mod.spf.K_stress_tensoryxtest(mod.vx)+(mod.p-mod.spf.K_stress_tensoryy)test(mod.vy)-mod.spf.K_stress_tensoryztest(mod.vz)-mod.spf.K_stress_tensorzxtest(mod.wx)-mod.spf.K_stress_tensorzytest(mod.wy)+(mod.p-mod.spf.K_stress_tensorzz)test(mod.wz))*(dvol)
what can be the issue?
thank you,
all the best,
V.
- Function: ^
- Defined as: (0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11))
- Defined as: (((0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)))*1.4142135623730951)*((-(c0-(((fc*rho)*g)*z)))/((epII*1.4142135623730951)^2))
- Defined as: (nT>nb)*((((0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)))*1.4142135623730951)*((-(c0-(((fc*rho)*g)*z)))/((epII*1.4142135623730951)^2)))
- Defined as: (mod.uz+mod.wx)*((nT>nb)*((((0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)))*1.4142135623730951)*((-(c0-(((fc*rho)*g)*z)))/((epII*1.4142135623730951)^2))))
- Expression: dvol*(-((mod.uz+mod.wx)*((nT>nb)*((((0.5*((0.5*((((2*(((ep12^2)+(ep13^2))+(ep23^2)))+(ep11^2))+(ep22^2))+(ep33^2)))^(-0.5)))*(0.5*(2*ep11)))*1.4142135623730951)*((-(c0-(((fc*rho)*g)*z)))/((epII*1.4142135623730951)^2))))))
- Expression: dvol*(-mod.spf.K_stress_tensorxz)
- Expression: ((mod.p-mod.spf.K_stress_tensorxx)*test(mod.ux)-mod.spf.K_stress_tensorxy*test(mod.uy)-mod.spf.K_stress_tensorxz*test(mod.uz)-mod.spf.K_stress_tensoryx*test(mod.vx)+(mod.p-mod.spf.K_stress_tensoryy)*test(mod.vy)-mod.spf.K_stress_tensoryz*test(mod.vz)-mod.spf.K_stress_tensorzx*test(mod.wx)-mod.spf.K_stress_tensorzy*test(mod.wy)+(mod.p-mod.spf.K_stress_tensorzz)*test(mod.wz))*(dvol)
thank you,
all the best,
V.
