Phase animation in COMSOL 4.1
Is it possible to get a phase animated plot of a RF solution in COMSOL 4.1?
Thanks.
6 Replies Last Post 08.02.2012, 10:25 GMT-5
Posted: 1 decade ago 30.03.2011, 11:11 GMT-4
you have the arg() function or atan2(imag(yourVariable),real(yourVariable)) way, or via a table defined in the postprocessing Defined Variable node
Hi you have the arg() function or atan2(imag(yourVariable),real(yourVariable)) way, or via a table defined in the postprocessing Defined Variable node -- Good luck Ivar
Posted: 1 decade ago 31.03.2011, 08:29 GMT-4
Thanks Ivar. I'm not really sure on how to do that. I have solved a RF model in the frequency domain and I can use the "player" feature of 4.1 to animate the solution in a frequency sweep, but I cannot animate the solution changing the phase (solution at angle) for a fixed frequency. Where should I use the functions that you say?
Iker.
Thanks Ivar. I'm not really sure on how to do that. I have solved a RF model in the frequency domain and I can use the "player" feature of 4.1 to animate the solution in a frequency sweep, but I cannot animate the solution changing the phase (solution at angle) for a fixed frequency. Where should I use the functions that you say? Regards, Iker.
Posted: 1 decade ago 01.04.2011, 02:41 GMT-4
Hello!
You have to change the player setting for "sweep type" to "dynamic data extension".
This will work, if your variable is something like V = Vmax*exp(j) for complex calculation.
Ralf
Hello! You have to change the player setting for "sweep type" to "dynamic data extension". This will work, if your variable is something like V = Vmax*exp(j) for complex calculation. Ralf
Posted: 1 decade ago 07.02.2012, 16:50 GMT-5
Are there any better instructions for doing RF phase animations? The instructions in this thread are too terse for me to understand.
Posted: 1 decade ago 08.02.2012, 09:25 GMT-5
Hi!
One example...but for MEF.
Ralf
Hi! One example...but for MEF. Ralf
Posted: 1 decade ago 08.02.2012, 10:25 GMT-5
Hi Ralf,
this is something I had been looking for for a while. Thanks a lot and my vote for you.
Cheers
Edgar
P.S. Just wondering how they define their terminolgy at COMSOL. Couldn't they just simply call it phase?
Hi Ralf, this is something I had been looking for for a while. Thanks a lot and my vote for you. Cheers Edgar P.S. Just wondering how they define their terminolgy at COMSOL. Couldn't they just simply call it phase?
