what is the reason for the error of conditioned preconditioner. Increase factor in error estimate to 532.6030621254678
Hi guys,
I am facing difficulties in solving my model, always comes am error by showing a Warning: Ill-conditioned preconditioner. Increase factor in error estimate to 532.6030621254678. What should i do to over come this error? Another thing, when mention less value or current (A/m²), this warning doesn't come but when i give a higher value of current (A/m²), this message is coming. Please give me some idea.
Rashed
1 Reply Last Post 29.03.2011, 15:18 GMT-4
Posted: 1 decade ago 29.03.2011, 15:18 GMT-4
It can (but not necesarily) come from a scaling issue, your dependent variables are too different and needsome prescaling that COMSOL is not capable of detecting (although mostly it manages to scale "automatically"
try to (in V4) to set the solver log to detailed. Often then you get the scaling values and compare them to what you expect.
Again this could be an issue, but there are other reasons possible
Hi It can (but not necesarily) come from a scaling issue, your dependent variables are too different and needsome prescaling that COMSOL is not capable of detecting (although mostly it manages to scale "automatically" try to (in V4) to set the solver log to detailed. Often then you get the scaling values and compare them to what you expect. Again this could be an issue, but there are other reasons possible -- Good luck Ivar
