Coupling to a ring resonator
I am having trouble with coupling from a waveguide to a ring resonator. Light is guided along the waveguide however it is not coupled to the ring resonator (the gap is close enough). How should I define the boundary conditions? I basically would like to see the spectrum of the ring resonator. Is it possible in Comsol?
thanks,
Damla
5 Replies Last Post 12.03.2013, 03:50 GMT-4
Posted: 1 decade ago 17.03.2011, 16:37 GMT-4
your gap must be "closed" hence be part of the simulation, else the field/flux is not going to "jump the gap" But the material properties of this gap is not necessarily a solid, "empty" vacuum is also possible, with its RF properties, but it must be there and meshed
Hi your gap must be "closed" hence be part of the simulation, else the field/flux is not going to "jump the gap" But the material properties of this gap is not necessarily a solid, "empty" vacuum is also possible, with its RF properties, but it must be there and meshed -- Good luck Ivar
Posted: 1 decade ago 20.04.2012, 15:30 GMT-4
Hi Damla,
I'm trying to do the same thing as you, I was wondering if you have any success in modeling the ring resonator in comsol and/or what troubles do you found on the way.
Thanks in advance.
Felipe
Hi Damla, I'm trying to do the same thing as you, I was wondering if you have any success in modeling the ring resonator in comsol and/or what troubles do you found on the way. Thanks in advance. -- Felipe
Posted: 1 decade ago 23.04.2012, 08:42 GMT-4
Hi Felipe and Damla,
I'm also studying the effect of coupling waveguides to a ring resonator. May we share the result of your simulation and compare the notes if you able to get the results.
Please do email me at zuldrac@yahoo.com
Hi Felipe and Damla, I'm also studying the effect of coupling waveguides to a ring resonator. May we share the result of your simulation and compare the notes if you able to get the results. Please do email me at zuldrac@yahoo.com Thanks
Posted: 1 decade ago 01.11.2012, 18:04 GMT-4
Hi Felipe, Damia and Zulhisham,
I'm working on ring resonator now and I would like to do a simulation with an axial symmetric geometry to find the ring modes.
But I didn't see any confined mode. Have you ever tried to do this kind of simulation?
Thank you
Sara
Hi Felipe, Damia and Zulhisham, I'm working on ring resonator now and I would like to do a simulation with an axial symmetric geometry to find the ring modes. But I didn't see any confined mode. Have you ever tried to do this kind of simulation? Thank you Sara
Posted: 1 decade ago 12.03.2013, 03:50 GMT-4
Hi Sara,
I am doing the same thing as you, but I have no idea how to use the axial symmetric geometry to analysis the mode in the cross section of a ring resonator which is coupling with a slab waveguide. Have you manage to see mode there? Could you share some setting tips?
My email is ying,ma@tu-harburg.de
Thanks alooooot :)
Ying
Hi Sara, I am doing the same thing as you, but I have no idea how to use the axial symmetric geometry to analysis the mode in the cross section of a ring resonator which is coupling with a slab waveguide. Have you manage to see mode there? Could you share some setting tips? My email is ying,ma@tu-harburg.de Thanks alooooot :) Ying
