How to sum two graphs in comsol?
I have builden in global definition branch two interpolation function.
I need to sum this two function and generate one graph.
In other words there is f(x) and g(x) which don't expression in elementary functions.
I want to plot graph like:
F(x) = f(x) + g(x);
How to do it?
5 Replies Last Post 21.07.2017, 13:05 GMT-4
Posted: 8 years ago 21.07.2017, 12:20 GMT-4
Andrey,
Use expression int1(x)+int2(x) to plot the sum of interpolation functions int1(x) and int2(x), as shown in the attached mph file.
Sergei
Andrey, Use expression int1(x)+int2(x) to plot the sum of interpolation functions int1(x) and int2(x), as shown in the attached mph file. Regards, Sergei
Posted: 8 years ago 21.07.2017, 12:33 GMT-4
Sergei, can you to overwrite this file with version 5.2 or previous? I haven't late issue.
Posted: 8 years ago 21.07.2017, 12:46 GMT-4
Andrey,
Attached is v5.2 file.
Sergei
Andrey, Attached is v5.2 file. Regards, Sergei
Posted: 8 years ago 21.07.2017, 13:00 GMT-4
Sergei!
Thanks a lot, and I love you.
Can you explain me one thing:
Why are you using in X-axis parameter "arc lenghth"?
To my mind need to take "expression" with value "t".
Sergei! Thanks a lot, and I love you. Can you explain me one thing: Why are you using in X-axis parameter "arc lenghth"? To my mind need to take "expression" with value "t".
Posted: 8 years ago 21.07.2017, 13:05 GMT-4
Andrey,
I use "x" as argument of the function because demo example is stationary type of problem.
As I understand, your problem is Time-dependent and you should use expression int1(t)+int2(t) in that case.
Sergei
Andrey, I use "x" as argument of the function because demo example is stationary type of problem. As I understand, your problem is Time-dependent and you should use expression int1(t)+int2(t) in that case. Regards, Sergei
