magnetic flux density (B) and magnetic field (H) in a simple solenoid
I found some strange results using the magnetic field solution in a complex geometry, so I have tried simple ones, as described below.
Considering the interior of a solenoid with a linearized soft ferromagnetic material (say relative permeability 1000), the solution for the magnetic field H inside the solenoid is different from the obtained with the soft ferromagnetic material replaced by air. I was expecting the same results for the magnetic field H. What may be wrong?
Thanking in advance.
0 Replies Last Post 07.03.2011, 14:27 GMT-5
Hello Ângela Ferreira
