PM generator current and voltage
Posted 21.06.2017, 05:55 GMT-4 Low-Frequency Electromagnetics, Results & Visualization, Studies & Solvers Version 5.0, Version 5.1, Version 5.2 0 Replies
I'm simulating a PM generator and I'm getting a voltage using the multi-turn coil node , I'm also measuring the magnetic flux density inside the coil to calculate the voltage analytically. but the voltage that I get from the simulation is very low comparing to what I calculate analytically and measured experimentally. so my Comsol simulation is good until the changing magnetic field but I don't know the problem with the coil .
and is there any way to plot the voltage and the current at the same time because I can only get them separately , the voltage by considering an open circuit and the current by a short circuit .
If you have any suggestions about this point I will be immensely grateful.
Sincerely,
Moumen
Hello Abdelmoumin Allioua
