Problem with meshing by considering an outer region
Mohammadreza Barzegaran
I designed a machine in comsol 3.5a and it has 146000 numbers of elements which is appropriate by considering the type of PC that I have. But when I add a casing or region to this machine it doesn’t mesh; however, it meshes by changing maximum element size to 8 million which is too much and unacceptable. Please tell me what can I do?
1 Reply Last Post 19.02.2011, 04:35 GMT-5
Posted: 1 decade ago 19.02.2011, 04:35 GMT-5
check your mesh carefully, you have probably some small elements being created by the intersection of some of your lager parts.
You need a "clean" geoemtry with geometrical objects really adjacent, without small gaps and small details that have no physical interest
Hi check your mesh carefully, you have probably some small elements being created by the intersection of some of your lager parts. You need a "clean" geoemtry with geometrical objects really adjacent, without small gaps and small details that have no physical interest -- Good luck Ivar
