Longer simulation study
Posted 23.03.2017, 07:24 GMT-4 Simulation Apps, Results & Visualization, Studies & Solvers Version 5.1 2 Replies
Hello everyone,
I'm facing an usual problem with a comsol time dependent simulation study. In the study settings, upon changing the upper limit of the time range by a decade, the simulation doesn't show any physical response. While it was completely fine when the study setting was up to a certain limit in range, considering I didn't make any further changes in resolution or meshing in my physical model, going to one more decade level in the range doesn't produce any results. Could it be related to any other setting I might be unaware of?
To give you context I'm running a time dependent study of 0-10ms with a resolution of 1e-7 and relative tolerance of 1e-6. And I'm being able to run it when this range is 1ms but after that it just doesn't produce any result.
Any help would be appreciated.
2 Replies Last Post 23.03.2017, 22:07 GMT-4
