Failed to evaluate variable Jacobian. - Variable: mat.nu ,Geometry: 1, Domain: 1
Hello everyone,
I am new in comsol. I am using comsol V4.0a.
I am trying to simulate of electromagnetic force problem.
But I am having the following prob.
Variable: mat.nu ,
I cant find out the error.Please help me.
Ayan
2 Replies Last Post 07.03.2011, 12:50 GMT-5
Posted: 1 decade ago 08.02.2011, 06:24 GMT-5
you try to calculate your mechanical problem also in the air domain. Then there are missing material parameters, e.g. Poisson ratio for air. If you want to calculate mechanical behaviour in the metal domains just deselect the air from the "solid mechanics" tab.
Hi you try to calculate your mechanical problem also in the air domain. Then there are missing material parameters, e.g. Poisson ratio for air. If you want to calculate mechanical behaviour in the metal domains just deselect the air from the "solid mechanics" tab.
Posted: 1 decade ago 07.03.2011, 12:50 GMT-5
I have same prob with my model ( V 4.1 a )
as you said I removed air from domain but still have same porb.
would you please check it for me?
I have same prob with my model ( V 4.1 a ) as you said I removed air from domain but still have same porb. would you please check it for me?
