Selecting one boundary of an identity pair
Dimitrios Agriostathis
I want to select the source and destination boundaries for a copy operation in building the mesh at an identity pair. For this purpose I would like to be able to select the boundaries of the identity pair separately without using an explicit selection, however I can't manage to do this using other kinds of selections because the boundaries can't be distinguished in the geometry. Is there a way around this?
2 Replies Last Post 06.03.2017, 12:07 GMT-5
Posted: 7 years ago 06.03.2017, 10:36 GMT-5
If you have two separate objects for domains , then you can assign each object and name it in geometry. Those boundaries will be available fro selection in layer on all the model nodes.
Posted: 7 years ago 06.03.2017, 12:07 GMT-5
Thank you for your response. What do you mean by "selection in layer on all the model nodes" ?
[QUOTE] If you have two separate objects for domains , then you can assign each object and name it in geometry. Those boundaries will be available fro selection in layer on all the model nodes. [/QUOTE] Thank you for your response. What do you mean by "selection in layer on all the model nodes" ?
