Flux over time Graph /Plot
Muhammad Shahid Manzoor
I have Richard's equation model with two no flow boundaries on sides of square with top boundary as pressure head at 0.00001 m and bottom boundary as pressure head at 0 m . Model has initial conditions of pressure 0.001 pascal also with fracture thickness of 0.2 mm for fracture flow.
Now i need to plot a graph with flux over time. I have searched in 1-D plot group , but there is no option for flux over time for Richard's equation.
thanks
2 Replies Last Post 01.03.2017, 11:01 GMT-5
Posted: 7 years ago 27.02.2017, 04:03 GMT-5
Hi Muhammad,
Richards' equation physics (usually labelled 'dl') stores values for density and velocity fields, so if you want to see the flux on a boundary you have to type
dl.rho*dl.u (for horizontal flux)
dl.rho*dl.v (for vertical flux)
I hope this can help you!
Tommaso
Hi Muhammad, Richards' equation physics (usually labelled 'dl') stores values for density and velocity fields, so if you want to see the flux on a boundary you have to type dl.rho*dl.u (for horizontal flux) dl.rho*dl.v (for vertical flux) I hope this can help you! Tommaso
Posted: 7 years ago 01.03.2017, 11:01 GMT-5
Hi Tommaso
thanks for the tip it worked. As i wanted to have it in m^3/s so i used this expression by using boundary integration method and global evaluation.
intop1(dl.v*dl.D)
Hi Tommaso thanks for the tip it worked. As i wanted to have it in m^3/s so i used this expression by using boundary integration method and global evaluation. intop1(dl.v*dl.D)
