Determining if Maxwell Stress Tensor is correct for DEA model
Posted 28.01.2011, 16:56 GMT-5 MEMS & Nanotechnology, MEMS & Piezoelectric Devices, Geometry, Mesh, Studies & Solvers, Structural Mechanics Version 3.5a 1 Reply
Hello all,
I have been trying to solve a crenelated DEA model using the electrostatics module, plane stress, and the ALE module. I have been going back and forth on the meshing and the boundary conditions necessary to make the Maxwell Stress Tensor work correctly. I have looked at previous threads and most say that the boundary and mesh needs to be symmetric with respect to the boundary at which the force is applied. I have tried to accomplish this by using a boundary layer mesh and a far away / large exterior boundary to remove edge effects. The problem I have is that I am not sure if the deflection amount that I am seeing is correct. I try to do a mesh convergence analysis to see if changing the mesh size actually makes the solution converge but am getting nowhere. Has anyone run into a similar issue and can assist or has words of advice? I simply cannot trust the solutions that I am getting.
I have attached my unmeshed model.
Thank you in advance,
Alek
Alek
1 Reply Last Post 29.01.2011, 11:39 GMT-5
