Re:vibration module
Hello I am looking for vibration module of ultrasonic machining can you help me out thanks
3 Replies Last Post 19.01.2011, 15:49 GMT-5
Posted: 1 decade ago 18.01.2011, 05:53 GMT-5
there is no specific module I believe, structural should do for vibratons, if you want the full PZT check the matrix of COMSOL modules for the PZT physics, or better ask your local COMSOL rep. to be sure
Hi there is no specific module I believe, structural should do for vibratons, if you want the full PZT check the matrix of COMSOL modules for the PZT physics, or better ask your local COMSOL rep. to be sure -- Good luck Ivar
Posted: 1 decade ago 19.01.2011, 15:41 GMT-5
thanks but for tool rotation how we can do module its same like rotational blade.?
Posted: 1 decade ago 19.01.2011, 15:49 GMT-5
In ACDC there are some exampls of rotary machines, in Fluidics too, they work essentially with assembly mode and identity pairs for the joining rotation, but are ment to be for rotation around a fixed axis
Hi In ACDC there are some exampls of rotary machines, in Fluidics too, they work essentially with assembly mode and identity pairs for the joining rotation, but are ment to be for rotation around a fixed axis -- Good luck Ivar
