Evaluate mass flow rate needed to remove a certain heat flux
Posted 13.11.2016, 15:23 GMT-5 Fluid & Heat, Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), Modeling Tools & Definitions, Parameters, Variables, & Functions Version 5.0 1 Reply
I'm trying to solve the following problem:
I have a 3D model of a box of stainless steel, with an electrical resistance on the top wall and an insulant material all around the box. At the bottom is needed a cooling circuit to remove the heat flux and to reach the steady state. I would like to obtain the mass flow rate needed to keep constant (with a certain tolerance) the temperature at the bottom plate of the box (I mean the plate in contact with the cooling circuit). How can I do? I'm sure that it is possible in COMSOL but I can't find how.
I selected heat transfer and laminar flow modules to model the system. I hope I've been clear.
Thanks for the attention.
Hello Giovanni Giansiracusa
