13.01.2011, 04:34 GMT-5
have you tried to put a variable in the max mesh size of your 4.1 module, There are some examples around on parametrized mesh size, so some way must be possible
13.01.2011, 04:52 GMT-5
Yes, I've tried to put a parameter in the max mesh size field, for example 'x' (then the max mesh size should increase as 'x'), but I does not work. Error is : "Unknown model parameter."
[QUOTE]
[/QUOTE]
Magnus Ringh
COMSOL Employee
13.01.2011, 05:33 GMT-5
The mesh parameters cannot depend on the space coordinates (such as x), but in version 4.1 you can use global parameters for a parameterized mesh size. See the following downloadable example from the COMSOL Support Knowledge Base:
www.comsol.com/support/knowledgebase/1103/
It shows how to parameterize the mesh size so that the mesh resolves the wave for varying wavelengths.
Magnus Ringh, COMSOL
http://www.comsol.com/support/knowledgebase/1103/
13.01.2011, 07:03 GMT-5
OK, but in this case the max mesh size is constant for a domain, which not I want. So I guess that in my case the only way to proceed is to make a lot of different layers of increasing mesh density.
Thank your for your answers;
[QUOTE]
[/QUOTE]
13.01.2011, 13:01 GMT-5
you can use a log or exp progressing shape distribution of the nodes on the lateral edges, and like that get un uneven distribution
