Modeling of Mass,Spring and Damper system
HI all,
i would like to ask How could i to make modeling of mass,spring and damper system ??
i attached a photo to discribe what i mean
thanks alot
Hassan
1 Reply Last Post 25.12.2010, 04:55 GMT-5
Posted: 1 decade ago 25.12.2010, 04:55 GMT-5
there are several ways around:
1) the mathematical one: write out the PDEs compare to the COMSOL internal coefficient PDE and adapt the different parameters, define your domain 1D probably draw a line from 0 to 1, and off you go :)
2) replace the spring k by a simple 1D beam/bar compression spring, add the damping and solve as a simple strutural case
Hi there are several ways around: 1) the mathematical one: write out the PDEs compare to the COMSOL internal coefficient PDE and adapt the different parameters, define your domain 1D probably draw a line from 0 to 1, and off you go :) 2) replace the spring k by a simple 1D beam/bar compression spring, add the damping and solve as a simple strutural case -- Good luck Ivar
