how to get data of table by matlab
I want to get the data of table under the matlab environment. How can I do? What is the syntax?
Thank you!
2 Replies Last Post 20.06.2012, 05:22 GMT-4
Hello Noritaka Yusa
Posted: 1 decade ago 28.07.2011, 15:50 GMT-4
Thanks to Noritaka, here is one solution:
Here is a way to get the data of table under the matlab environment.
the syntax is "a=model.result.table('tbl1').getReal or b=model.result.table('tbl1').getImag"
here "a" and "b" are the variables of matlab which are defined by yourself.
The value of the table is a complex.
I also found out how to save a table as .txt or .xls files , namely:
model.result.table(minaTbl).save(['C:\...\comsolLivelink\' Tbl '.txt']);
model.result.table(minaTbl).save(['C:\...\comsolLivelink\' Tbl '.xls']);
Hope it helps.
Mina
Thanks to Noritaka, here is one solution: Here is a way to get the data of table under the matlab environment. the syntax is "a=model.result.table('tbl1').getReal or b=model.result.table('tbl1').getImag" here "a" and "b" are the variables of matlab which are defined by yourself. The value of the table is a complex. I also found out how to save a table as .txt or .xls files , namely: model.result.table(minaTbl).save(['C:\...\comsolLivelink\' Tbl '.txt']); model.result.table(minaTbl).save(['C:\...\comsolLivelink\' Tbl '.xls']); Hope it helps. Mina
Posted: 1 decade ago 20.06.2012, 05:22 GMT-4
hello
i have the same problem but it's about the result ,thanksgiving
instead of having a table of 4 columns I found a table with two columns of false data as you can see in the atach file
hello i have the same problem but it's about the result ,thanksgiving instead of having a table of 4 columns I found a table with two columns of false data as you can see in the atach file
