Computer configuration for COMSOL
Now my computer running COMSOL will show the disk is not enough, want to buy a good point of the computer to run COMSOL, we have not recommended? Now I don't know the computer configuration. What is the relationship between computer configuration and mesh, degrees of freedom and so on?
2 Replies Last Post 07.09.2016, 21:03 GMT-4
Posted: 8 years ago 07.09.2016, 11:11 GMT-4
For a primer on the factors that influence how much memory it takes to solve various types of models, see this link: www.comsol.com/blogs/much-memory-needed-solve-large-comsol-models/
Short of buying a new computer, you will find some advice on various techniques that will reduce memory usage here: www.comsol.com/support/knowledgebase/1030/
If you should consider buying a computer, for hardware recommendations, see this link: www.comsol.com/support/knowledgebase/866/
For a primer on the factors that influence how much memory it takes to solve various types of models, see this link: https://www.comsol.com/blogs/much-memory-needed-solve-large-comsol-models/ Short of buying a new computer, you will find some advice on various techniques that will reduce memory usage here: https://www.comsol.com/support/knowledgebase/1030/ If you should consider buying a computer, for hardware recommendations, see this link: https://www.comsol.com/support/knowledgebase/866/ Best regards, Jeff
Posted: 8 years ago 07.09.2016, 21:03 GMT-4
Thank you, Thank you very much!
