Submerged cantilever beam modal analysis
Since I am not so sure how to do modal analysis for sumberged beam, I solved the harmonic case using Acoustic Module based on fluid-structure analysis. My question is... comparing with the published data, my modal analysis and air harmonic analysis correspond with them correctly but my water harmonic results show more significant reduction in natural frequency due to fluid mass loading effect. Can any one tell me why or where to look?
For water harmonic/air harmonic cases, I applied the plane harmonic wave to the beam and applied the interacting boundary condition for each module(structure and acoutic) so they can communicate as feedback system since one output becomes an input to the other. But I only applied the boundary condition on the top portion of the beam.
Since it's not that meaningful to do 3 D analysis, I've been doing with 2 D.
Thanks in advance for any comment or suggestions you could give!!!
6 Replies Last Post 24.12.2010, 13:46 GMT-5
Posted: 1 decade ago 22.12.2010, 16:48 GMT-5
first of all I would refer to the excellent book: Vol3 Modelling of Mechanical Systems Fluid-Structure Interaction of F.Axisa and J. Antuns from B&H Elsevier isbn 978-0-750-66847-7 (vol 1 and 2 are as good)
Then following chapter 2 inertial coupling I would suggest to use only structural and load the boundaries with a load of then type damp*u*lambda
or in a more general term (for the u-x direction)
( stiffx+ lambda * damp -lambda^2 * rho ) * u
At least starting with physics equation as loads you do not need to fully solve all the NS tobegin with, thereafter one can add a true fluid around and see how that matches the previous results
Hi first of all I would refer to the excellent book: Vol3 Modelling of Mechanical Systems Fluid-Structure Interaction of F.Axisa and J. Antuns from B&H Elsevier isbn 978-0-750-66847-7 (vol 1 and 2 are as good) Then following chapter 2 inertial coupling I would suggest to use only structural and load the boundaries with a load of then type damp*u*lambda or in a more general term (for the u-x direction) ( stiffx+ lambda * damp -lambda^2 * rho ) * u At least starting with physics equation as loads you do not need to fully solve all the NS tobegin with, thereafter one can add a true fluid around and see how that matches the previous results -- Good luck Ivar
Posted: 1 decade ago 22.12.2010, 19:58 GMT-5
Hi Ivar,
Thanks for the reply... what do you mean by "damp*u*lambda"? Should it be "rho*u*lambda"?
Does Acoustic module solve NS too? I thought they only solve wave equation or helmholtz.
Hi Ivar, Thanks for the reply... what do you mean by "damp*u*lambda"? Should it be "rho*u*lambda"? Does Acoustic module solve NS too? I thought they only solve wave equation or helmholtz.
Posted: 1 decade ago 23.12.2010, 02:59 GMT-5
my formula was a general one to e adapted for your fase with a damping (related to lambda and to u) and a additional mass part (related to lambda^2 and to u), indeed check carefuly the units
Hi my formula was a general one to e adapted for your fase with a damping (related to lambda and to u) and a additional mass part (related to lambda^2 and to u), indeed check carefuly the units -- Good luck Ivar
Posted: 1 decade ago 23.12.2010, 14:47 GMT-5
Hi Ivar,
Thanks for the quick reply again. Since I am only interested in natural frequency of the bar in the water, damping is not my concern. For the reason, I chose "no damping" to my model. Without relating additional damping term, can it be done only relating the additional mass due to fluid load?
BTW... Happy holidays to you, Ivar!
Jin
Hi Ivar, Thanks for the quick reply again. Since I am only interested in natural frequency of the bar in the water, damping is not my concern. For the reason, I chose "no damping" to my model. Without relating additional damping term, can it be done only relating the additional mass due to fluid load? BTW... Happy holidays to you, Ivar! Jin
Posted: 1 decade ago 24.12.2010, 04:23 GMT-5
yes you should be able to get along only with structural and some "physics" added mass boundary load for the fluide displaced. Get hand on a copy of "Modelling of Mechanical Systems Fluid-Structure Interaction" from your library you will find the physics and many examples therein. The volume should exist in French too, as it was normally written first in French I have heard, but that mght not help you ;)
Hi yes you should be able to get along only with structural and some "physics" added mass boundary load for the fluide displaced. Get hand on a copy of "Modelling of Mechanical Systems Fluid-Structure Interaction" from your library you will find the physics and many examples therein. The volume should exist in French too, as it was normally written first in French I have heard, but that mght not help you ;) -- Good luck Ivar
Posted: 1 decade ago 24.12.2010, 13:46 GMT-5
Hi Ivar,
I got the book now... it seems very good book to start with. While I am at it, thanks for showing me a good direction. I really appreciate your feedback! Happy holidays!
Jin
Hi Ivar, I got the book now... it seems very good book to start with. While I am at it, thanks for showing me a good direction. I really appreciate your feedback! Happy holidays! Jin
